Removal of chrome top cap on shock ???
Is this possible.
Was planning on switching out my 12.5 shocks for 12.0 shocks.
I have a pair of 12 inch FXDB shocks and one of them has a gouge and a dent in the top cap. I have another set of 12.5 inch FXDC shocks and was wondering if I could switch caps? If it is possible how is it done?
Or if anyone has an extra 12 inch dyna shock available let me know.
Thanks in advance.
Cheers,
Tom
Thanks in advance.
Cheers,
Tom
I think that would give the shocks a "minimal" look. If its easy, I will try and see how I like it.
Thanks for the info guys.
Ghostrider mentioned that he used his drill press. I am assuming then that the shock needs to be compressed to allow for the washer to be twisted off. if this is the case I am just going to get another shock as I dont have access to a shop unfortunately. But thanks for the info. It's much appreciated.
Thanks again.
Tom
Thanks again.
Tom
It is hard to explain but I'll try. The procedure is done with the shock upside down. Open up the drill press vise so that the retainer on the top of the shock is inside the jaws of the vise and the top cover of the shock is setting on the jaws. With the chuck of the drill press setting down on the top of the bottom mounting eye of the shock, pull the drill press lever down like if you were drilling a hole through something. That will compress the spring and push the upper shock mount down through the vise jaws. At this point the retainer ring will be loose and can be removed with a pair of pliers or if you are feeling lucky you can use your fingers. I have used this procedure for years without any problems. One other thing, I always lay a rag on each vise jaw to keep from scratching the chrome on the upper spring cover. It actually works very well. I came across this method years ago when I needed to take a shock apart and did not have the right tool for the job but I did have a floor drill press.
