Compensator Sprocket Upgrade
Old 03-27-2011, 12:09 PM
mud's Avatar
mud
mud is online now
muderator
Received 8,785 Likes on 2,066 Posts
Originally Posted by parts eeter
Just a thought... I believe that the 06 Dyna has a larger rear pulley than the 07 and up versions. Maybe somebody could chime in here and confirm this and if it would be an alternative to primary disassemby.
Yes the 006s have more desirable, in my opinion, gearing..........
......rear sprocket......
.............the 006 domestic is 70 tooth.
.......the 007 up domestic is
66 tooth
.....the 006 international is 68 tooth.
.....the 007 international is 64 tooth.
....gear........006.......
007 and up....005 back
....1st.......9.876......
9.312......10.11.......1st
....2nd.......6.81.......
6.421.......6.958......2nd
....3rd.......5.064......
4.774.......4.953......3rd
....4th.......4.164......
3.926.......3.862......4th
....5th.......3.477......
3.279.......3.15........5th
....6th.......2.96........
2.79.......no
.........drive belt for 006 domestic is 133 teeth
.........drive belt for 007 domestic is
131 teeth
..drive belt for 006 international is 132 teeth
international is 130 teeth
SuperGlide_805 (03-09-2018)
Old 03-27-2011, 01:09 PM
MisterPX's Avatar
MisterPX
MisterPX is offline
Depending on where the speed sensor is on your bike, you may also need to replace it for teh different belt sprocket.
Old 03-27-2011, 04:34 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
Originally Posted by jshull
the wire is to keep the chain moving in the same direction, for wear purpose. as far as the wedge it was from georges garage also, but you could get by with a 1/4 thick 2" wide peice of stock. I was lucky enough to borrow the tools.
I highly recomend the 30t, if you take your time and read your manual it is a breeze, I plan to do a full alingment tomorrow night on my bike per the manual. I get a helluva wobble, at 80ish.
So to do the Andrews 30T pully you need:
PRIMARY DRIVE LOCKING TOOL
______________________________
TRANS SPROCKET LOCKING TOOL
is that it?
Old 03-27-2011, 06:43 PM
parts eeter's Avatar
parts eeter
parts eeter is offline
I wonder if the 131 tooth belt will reach around the 70 tooth pulley from the 2006 bike? If so thats what I would do if I had an 07 up with the smaller rear pulley.
Thanks for the info Mud , I saved it in favorites.
Old 03-27-2011, 06:47 PM
jshull's Avatar
jshull
jshull is offline
you need the locking bar and a big *** socket to take the pulley bolt off, you could do it without the locking tool. I did my second one without it.
Old 03-27-2011, 06:54 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
You can make a locking tool, I sure wouldn't pay for one.
Old 03-27-2011, 08:01 PM
HD Bobber's Avatar
HD Bobber
I just dont want to damage anything while i'm cranking away on the nut.
Anyone want to sell me their pully locking tool?
Old 03-27-2011, 08:40 PM
dynabobster's Avatar
dynabobster
dynabobster is offline
Someone posted on one of the threads you can use the 30T pulley off the 2011 HD Tri-Glide and it is cheaper, somewhere around 65.00 ???
P/N 83595-11
Old 03-27-2011, 08:52 PM
rjsimmons's Avatar
rjsimmons
rjsimmons is offline
That only makes sense if you do not remove/install the sprocket, chain and clutch as one complete assembly, something the service manual indicates is necessary. I realize that were you to undertake this by yourself it would be difficult to remove/install these as one, so my presumption is that the wire is ONLY to remind the installer which way the chain is to rotate?
What length was the tool?
Old 03-28-2011, 06:53 AM
HD Bobber's Avatar
HD Bobber
I found this from one of the sponsors on the forum for $14.99, it's .7125" long:
http://mbsmfg.com/hadaprdrloba2.html
Quick Reply: Compensator Sprocket Upgrade
