Front Wheel Swap Without Jack
So, since I wrecked the bike I need to swap to my 21" wheel but I no longer have my bike Jack. I moved in to an apartment and left the jack with my cousin who lives quite a ways away. Does anyone have any suggestions on what I can do to lift this bad boy up and safely change wheels?
Here is a different approach. If you have access to a garage or someplace with a sturdy roof use straps to lift the front of the bike. 2-3 ratchet straps placed around the forks beneath the triple clamp should do it. A 1 inch strap is usually rated for 500 lbs. You only need to lift the front. If you line the bike up parallel to the trusses you can place one strap on each and it shouldn't be a problem supporting the load. Before I had a jack I used this method to lift the bike and it worked well.
I'd go with a car jack as well or even that homemade lift in the reply above. You don't need a lot of clearance to remove the wheel. You can loosen everything up on the ground then just lift the front a hair for complete disassembly.
You could get away with one of those newer style scissor lifts they put in cars now.
