2005 superglide Oil Change HELP
Old 06-18-2011, 07:54 AM
Mattee23's Avatar
Mattee23
Mattee23 is offline
Stage III
Default 2005 superglide Oil Change HELP
New Harley owner here attempting my first oil change. Underneath the bike there are 2 plugs on the drain pan and i removed them both and oil came out of both. One of them was on the bottom and a lighter (cleaner oil) came out and the other was on the Side and that was clearly the used motor oil. My question is what did i drain on the bottom plug and how do i fill it back up? It appears the two bolts are on the same "tank" so i am a bit confused....please help. Thanks
Old 06-18-2011, 08:19 AM
Billyram's Avatar
Billyram
Billyram is offline
You drained the engine and tranny oil. That's OK. Just after installing a new oil filter refill the engine and tranny with the proper amount of oil. I don't know but if you're going this far you may want to do your primary too and check the clutch adjustment.
Billy
Old 06-18-2011, 08:21 AM
Mattee23's Avatar
Mattee23
Mattee23 is offline
Stage III
Do you know if i fill them both in the same spot? Do you know how much oil and is it the same kind? thanks again.
Old 06-18-2011, 08:34 AM
hell hound's Avatar
hell hound
hell hound is offline
the oil fill is the the big plug on the right side that you can remove by hand and the transmission is a few inches toward thee back of the bike and will be a large allen bolt, it will also have a dipstick on it. My 06 superglide takes one quart in the tranny and two and a half in the motor oil. They dont mix and are not in the same pan, evan though it appears that way. any hd shop can give you the proper fluids for both
Old 06-18-2011, 08:42 AM
Billyram's Avatar
Billyram
Billyram is offline
You fill your crank case through the hand removable dip stick and the tranny through the plug on top of the tranny that uses a hex socket wrench. Fill the tranny with the bike upright and the crank case with the bike on the jiffy stand. Use 20-50W Synthetic V-Twin oil in the crank case "Some put the same in the tranny" or use Synthetic 75-90W GL-5 gear oil. Don't over fill. 2.5qts in the crank case and 1qt in the tranny.
Edit: Check the tranny fluid while on the jiffy stand also.
Billy
Old 06-18-2011, 11:25 AM
Mattee23's Avatar
Mattee23
Mattee23 is offline
Stage III
Thank you all very much for your help. Anyone know the size of the hex wrench for the tranny? Thanks again.
Old 06-18-2011, 11:46 AM
Billyram's Avatar
Billyram
Billyram is offline
Mine is 3/8"
Billy
Old 06-18-2011, 02:11 PM
capttxrngr's Avatar
capttxrngr
capttxrngr is offline
Two things I have, the tech book for the bike and FixMyHog DVDs. Reading how to do something is one thing but I like to see how it is done. The DVDs are for Softtails and Dynas and mainly show Softails on the first but more Dynas with the 3 DVD series.
Old 06-18-2011, 07:24 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is online now
Received 4,314 Likes on 2,358 Posts
The trans takes 20 -24 ozs. of oil. I put 22 ozs. in both of mine. I think if you put more than 24 it will vent (little rubber hose on the trans cover) between the trans case and inner primary cover. Then you'll be scratching your head where that oil leak came from.
Old 06-19-2011, 03:47 AM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
Go here and get a free online version of your owners manual
https://www.harley-davidson.com/en_U...s-manuals.html
You just have to create a free online account.
Quick Reply: 2005 superglide Oil Change HELP
