Handlebar Turn Signals
Are there relocation kits to get the signals off the handlebar? I've seen them on bars attached to the forks, but I'm not sure if those HDs are from the factory that way or owner relocated...
I don't like them being on the handlebars. Look kinda girly there. Aftermarket kit? Thanks
Will check-out Kuryakyn....thanks
I found one kit at Dennis Kirk, but also read a 'way-back' post on this forum that complained about that particular HD part # not fitting properly. Found two other HD part #s in that same thread that the posters said were correct and then not correct...lol. I'm gonna do some more research. Couldn't find a front TS relocation kit/bar at K tho.
In Texas you DO NOT have to have turn signals to pass inspection.
http://www.txdps.state.tx.us/msb/msbfaqs.htm - FAQ 16
But if you want them I like the look of mounting them down on the forward controls.
I also have some HD relocation brackets for 49mm forks I would be willing to part with.
