Front Motor Mount Shim-With Pics
So I started noticing an excessive vibration on my 2009 FXDL at about 2900 to 3100 RPM especially in 6th gear. It always had a vibration but it seems to be getting worse. I was in the process of removing the emission canister that is mounted to the front mount bracket on California models. I figured this was a good time to try the shims that I had read about in several other threads.
I placed a scissor jack underneath the motor although several posts said that was unnecessary. I can tell you it was absolutely necessary or I would not have been able to line up the bolts to get them back in. In any case as the other post said would happen, as I loosened the mount it pulled back from the frame about the width of a single 3/8" washer. I simply fit one washer on the top and one on the bottom and reinstalled the blots. The whole proceeded took 5 minutes.
I did notice prior to loosening the mount blots that I could jack the motor up about 1/4 inch without any lift in the frame. I don't know if this is normal because I have nothing to compare to. Does this mean the mount is sagging and failing?
I measured the thickness of the washers. 2mm exactly. The mount is several inches wide and I just cant see this making much of a difference. But a 300 mile ride this weekend should be pretty conclusive. I will report back on Sunday.
Attached are some pics of the mount with washers from above and below.
To be continued . . .
I think it helped mine. A few weeks ago I had tires installed at an indy. When he test rode it he told me he thought it had alot of vibration on deceleration. I told him I hadn't noticed and this is my first Harley so I had nothing to compare it too. Anyway, after reading about it on here, added two washers to each bolt. Not only could I tell a vast improvement, my wife commented about it next time she rode with me.
You said they "clearenced it". What exactly does that mean? Like you my mount looks like your before picture. Adding shims will not make it look like your after picture. What did they do?
Never Mind, I see now. They removed about 1/4 of material from the top of the rubber part of the mount. Interesting idea! I wil see if this is necessary.
pontiac69,
HD-MC,
You wouldn't be shimming it, but removing some of the rubber material with either a sharp knife or dremel. Problem with the dremel is they tend to bounce all over and put knicks in things. I think its worth a try if the shims don't work. Because the only other solution is a new mount anyway.
