Service Manual
Get the Harley Manuals. You will also want the "Electrical Diagnostic Manual" and the "Parts Catalog" Don't go cheap here, get the real books. The old saying that an ounce of prevention is worth a pound of cure holds so very true. If all you're going to do is change your oil and check your tire pressures; you probably don't need any of these manuals . . . but if you're going to do anything more . . . or . . . if you're going to have someone who doesn't have (or can't or won't read) these manuals work on your bike . . . . duh!
get the harley manuals. You will also want the "electrical diagnostic manual" and the "parts catalog" don't go cheap here, get the real books. The old saying that an ounce of prevention is worth a pound of cure holds so very true. If all you're going to do is change your oil and check your tire pressures; you probably don't need any of these manuals . . . But if you're going to do anything more . . . Or . . . If you're going to have someone who doesn't have (or can't or won't read) these manuals work on your bike . . . . Duh!
