Heavy duty clutch spring install ?
Do I need a spring compressor to install a heavy duty clutch spring? I am experiencing a bit of slippage in 5th gear since my big bore install. If I whack the throttle in 5th gear it will slip.
This was never an issue before the big bore build and only happens in 5th gear which is my top gear. No one here (at work) seems to know if I will need a clutch spring compressor or not for this install so I am sure someone here knows.
I am going to pull the clutch apart and check my steel rings as our tech has described and if they are burned I will replace the rings and the clutch plates. He said if they are not I should be fine. I am not hard on my clutch and my other bike has 75K miles on the stock clutch.
Anyway, a yes you need the spring compressor or no you do not would be great. My service manual is at home and yes, I am here at work.
Quick and Easy job with primary cover off. I used the Screamin Eagle spring and found that the clutch effort was manageable and the clutch gripped better when put to work. In my opinion the Screamin Eagle spring should have came in the bike when stock, because the stock spring was way to light for even slight mods on the engine.
I should also note that I install heavy duty clutch springs in every bike I have ever built, be it an atv, dirt bike, harley etc..
NCBANDIT
03-11-2019 04:52 PM
icebite1
19
07-15-2016 06:53 PM
Skippy49
02-19-2008 02:22 PM
