Service Manual torque range for fork tube caps is huge...
09-25-2012, 07:57 AM
The torque in the manual says somthing like 22-59 ft lbs .
Why is the range so large?
09-25-2012, 08:42 AM
Hydrolic pressure from cylinder compression? IDK.
09-25-2012, 09:31 AM
I looked up the torque for the 49mm fork tube caps & it is cofusing 16-43 ftlbs. I never torque mine just tighten them down and give the ratche a couple wacks with my hand. This has worked for me for last 35 years on all the bikes I've had and worked on.
09-25-2012, 10:08 AM
HD manual indicates 22-29ftlbs for the caps on my '03
09-25-2012, 10:23 AM
Quote:
Originally Posted by
Austin Dave
ya 25ftlbs sounds good to me
09-25-2012, 10:49 AM
The cap thread is steel but the fork-tube thread is Aluminum. Range in manual makes sense.
09-25-2012, 10:54 AM
using two different thread materials so they give you a span in case it leaks to go by.
09-25-2012, 12:36 PM
I usually torque to the lower end of given ranges in the manual
09-25-2012, 05:03 PM
snug then a bit more has always worked for me
09-25-2012, 05:06 PM
22-59 ft lbs is what my 2012 manual says
