Need a measurement from any Dyna....please
So I ripped the front end apart on the 07 Street Bob to 1) Sell the complete front end (not much luck so far) and 2) Start mounting the Switchback front end. Here's what Ive learned so far;
I can still use the 1" WG front axle from my set up with the spacers etc. and not have to convert to 25mm BUT...The caliper is a little too close to the rotor now. The Switchback fork leg puts its a little closer to the rotor than the Street Bob lower did. So if someone could take a measurement from a still assembled Dyna front end for me. What I need is this.....
Preferably with a steel rule or something accurate (i.e. not a tape measure), pretend their are no brake pads and measure from the outside face of the rotor to the inside edge of the caliper itself. Please see drawing for reference.
Im going to have to machine something to get the proper clearance trying to determine exactly how much i need to remove. Thanks in advance.
Crap!....so the caliper is basically centered over the rotor? If I start messing with spacers then I'm gonna end up have to change the offset of the rim....more money! Oh well, nothing comes easy. Ive only got maybe .200 of an inch now, dont think ive got room to make up the distance. Thanks.
Muddy
Can't you space the rotor or machine the hub (not sure which way it's gotta go) ...?
Might work better than screwing around with the fork leg or caliper ... just thought I'd throw the idea out there ...
I guess if you change the spacing of the rotor relative to the hub, you'll also have to adjust the width of any spacer on that side of the wheel accordingly ... but, I don't think that would change the centering of the wheel between the forks ...
R/
'Chop
R/
'Chop
