Will a 7" headlight fit my FXDL?
I want to replace the std 5 3/4" headlight with a 7" headlight on my 2003 FXDL.
I know I will have to enlarge the cutout on my windshield but besides that will I have any other problems?
The headlight I am looking at has a H4 55/60 Watt Xenon blub. Should I go with this type or look for something else?
I am wanting to increase visibility and also get rid of that yellowish light from the std headlight I have now.
Thanks all
Thanks all
When you say I'll need a mounting block, where do I find that?
Are you meaning something like this?
Or something like this?
By the way, this is the headlight I ended up ordering...
http://www.jpcycles.com/product/310-272
Thanks for the help!
the first one you posted (http://www.amazon.com/BKRider-Mounti...=5336075432-20) is the one you will need for the bottom mount light, you can also get the blocks that move the light forward or down etc
if your lower tree isnt already drilled for a bottom mount you will need to drill it to accept the mounting block but thats fairly simple to do
I just noticed that that mounting block says for 5 3/4" bottom mount headlights. Will that matter? I searched for the same thing for a 7" and I can't find one.
If I need to drill the hole, I'll be back on here for help!
I have done the 7" swap. You can see some of my older pics to see how it turned out. I just used the stock mounting block, but I didn't have windshield to worry about. I posted a walk through with pics too, if you check my profile for posts started by me, you can't miss it.
Good luck, you'll find it to be a really easy project.
