2011 FXDF Fat Bob Powercommander V question
Hi all,
I have tried searching quite a bit for this, but have yet to find an answer.
This is my setup:
2011 Dyna FXDF Fat Bob
Vance and Hines Big Radius 2 into 1 (baffles removed)
Screamin' Eagle Heavy Breather
Powercommander V fuel tuner
I am trying to locate a fuel map for my powercommander V. I've looked on the powercommander website, and had no luck for my particular set up.
Does anyone have any ideas or links to where I can get a map for my setup? So far I've found a bunch for a PCIII USB, but not a PCV. I've also found some for a 2:2, but not 2:1.
Thanks for your help.
Max
This is my setup:
Max
http://www.powercommander.com/powerc...dl=316&yr=2011
I had the same setup on my bike (2010 Wide Glide) and used the 4th map down, click above or paste the link in your browser. Map worked fine.
You can have them remote into your computer and adjust and set map settings while you have your puter hooked up to the bike. When I ran a PCV on my streetbob I had a tech from power commander remote in and adjust AFR and a few things while I chatted with them on the puter. Hope this helps
