Bolt end broken in frame??
The following 2 users liked this post by Hey Man:
81shovelhd! (04-28-2024),
smitty901 (04-28-2024)
The following 2 users liked this post by hardheaded:
Vec (04-29-2024)
Received 48,004 Likes
Hey Man (05-02-2024)
[QUOTE=Hey Man;21661711]Grind/file flt the area, center punch it, drill it, heat up the area and hammer in an ez out and you should be ok
What type bit?
Wojld his set do it?
Ya know.......This bolt has broken several timea.....Im almost tempted ti just leave it off!
What type bit?
Received 19,744 Likes
[QUOTE=81shovelhd!;21661777]
I do not think those bits would work well for getting that bolt out. Those are used for sheet metal or lighter drilling.
As stated above, get it flush, then center punch and drill with a 3/16 drill bit, then move up in size until you can get an EZ out or until you can get the bolt out with some heat. I would also soak it down with some PB Blaster as it is probably corroded in there and let it sit overnight.
Once you get the bolt out you could put a stud in there with some blue loctite and use a nut to hold the battery tray on. That way if you have to take it off you have access to the nut and can squirt some oil etc on it from time to time to keep it from seizing up.
The following 3 users liked this post by CoolBreeze3646:
[QUOTE=CoolBreeze3646;21661806]
How hard should I hit center punch........just enough to make a dent for drill bit?
Or should I actually create a hole?
Never did this so excuse my possibly obvious questions!
Tx!
Tx!
[QUOTE=81shovelhd!;21661922]
You just need to make a dent so the drill bit does not wander and you can drill in the center of the broken part.
No A1 oil will not work well, you need a penetrating type oil as stated above.
Let me suggest you find a friend who has done this before to show you how to do it.
pgreer (04-28-2024)
