Front turn signal relocation wiring
I did this on my 2012 street bob with Joker machine fork mounted turns. I ran wires all the way from the housing to the signals and solder/shrink tubed to the blue/purple wires up near the housing as well as the ground. I also used an LED intensifier so they would remain running and turn signals. I spliced into the blue/purple up near the housing and ran them down through the bars, then spliced in the intensifier to the lead coming from the turn signal on the fork. I just packed the extra wires into the stock tubing and ran it back through the handlebars. It worked for me.
http://jokermachine.com/products/har...converter.html
Do you have any pics of this? Or of your install... I would like to see what extra wires you're talking about
+1 on this. I thought I had a pic but must have erased it. I also located the spare connections in the wiring diagram in the back of the HD Service Manual. If you download the HD Front Signal Relocate Instructions for your bike, it will refer to these connections too.
To find the connectors under the tank, take seat off, pull the two fuel tank bolts, disconnect the fuel quick connect fitting, and carefully lift and move fuel tank backward a few inches(might place some old clean cloths underneath). There will be a wire harness shield held in place by two tabs - release the tabs and pull down the wiring and locate the two unused three pin connectors( one white for left signal, one black for right signal)
Pull out the large rubber grommet in the frame, right in front of your tank. Pull out the wiring and you should come across a black and white connector, each of which has three wires attached to it (see attached pic). There are lots of wires behind that grommet so it might take some digging to get them out. I clipped off the connectors and hard wired on mine, but if you have the HD relocation kit, it will include connectors that plug into these. This is how it is on 2012 and later Street Bobs. I'm assuming the Wide Glide is the same.
