Outer "Six Speed" transmission cover
Bought a chrome cover from a member and am getting ready to install it. Not sure the technical name for it, but it's the cover that says "six speed" on it and where the clutch cable enters. (This is a 2012 Fat Bob 103.)
Under clutch cable replacement, the manual says to drain the transmission fluid before removing the cover. Would like to avoid that and wait until I get the bike back on the road (spring) and get it warmed up before doing a fluid change.
So, if I don't drain the fluid, how much will come out when I remove the cover? If I lean the bike over on the jiffy stand, will that minimize the loss?
Need to remove the pipes as well and am wondering if I need to replace the seals between the pipes and the engine heads. Can these be re-used? Bike only has a few thousand miles on it.
Thanks!
Thanks!
Thanks everyone.
Jasonb, I assume your bike isn't a 103. Could my engine be any different? Hate to remove this cover and be swimming in fluid.
Can't see how I could possibly remove and replace this cover with my pipes on. Just no room. Would never get a torque wrench on the bolts. Your pipes must be different?
If your worried about losing fluid drain it and put it back in when your done... I'd do the job on your wheel chock. Of the 3 holes your trannys probably the cleanest anyway. If your bike only has a couple thousand miles on it your good for at least another 3K. Ive also reused exhaust gaskets without any problems
