Need help urgently please.........
I have a Kitech Performance Harley Fuel Injection Kit - Kitech Performance Harley Fuel Injection Kit Power Pro Fueler for Harley Davidson Big Twin Motorcycles part number PPF-10700.
(Safely modify or add performance parts to your fuel injected Harley-Davidson® motorcycle without the risk of running the engine too lean. Get the most out of your modifications Running too lean not only causes severe engine over-heating but you also loose out on extra horsepower, the PowerPro fueler adds fuel based on the load placed on the engine. This easy-to-use control unit plugs directly into the OEM wiring harness between the injectors and fuel injection control of the engines fuel management system.)
I urgently need a copy of the user guide / instruction manual. Is there anybody out there who can help me out please?
Maybe you can use this as a reference:
http://www.electronicjetkit.com/featuredescriptions.asp
or here:
http://www.electronicjetkit.com/techsupport.asp
It seems to be the same type of controller, just re branded for use in the UK.
Good luck!
or here:
Good luck!
or here:
Good luck!
or here:
Good luck!
Thank you very much!
