Ness fairing on fat bob
Just wanted to show it off. Still needs to be painted. I mounted it using 2 HD quick detach clamps and 2 zip ties to secure it to the headlight block. I have to get some smaller bolts, however, as these were too long. Used some 5/16 fuel line as the bolt spacers.
I originally had it mounted using a bracket I ordered from Arlen Ness, after discovering the headlight mount kit I got from phat performance parts isn't compatible with my Dyna. However it made the fairing cover the lower tree and stuck it out further which threw the look off to me.
Anyways here it is...
Sorry man didn't take a side pic.. I couldn't even get to take it out for a ride to test it out :/
I have a set of 1 1/2" and another set of 2" riser extensions from Jim's Spacer that I had tried out previously before going with the 2 1/2 inch. If you're interested in either set PM me. Maybe the 1 1/2" would work out for you.
