Stock pulley size
You could go down on the front pully, or up on the rear pulley, or you could do both.
This lowers the gear ratio.
It is recommended that if you change pulleys that you change the belt (not always necessary). Normally if you change the front pulley you will need a shorter belt. If you change the rear pulley, (sometimes) you have enough slack to properly adjust the belt.
Going one down on the front is just about equal to going up 3 on the rear.
ABQ-Jammer (02-15-2018)
Thats another reason Im going with a 68T rear. Eventually I plan on doing a 30T front pulley. So a 68T now will still allow me to run the stock belt AND keep it when I install the 30T front. The most common swap is a 30T front and a 70T rear but you would have to do the swap at the same time. There isnt enough slack in my stock belt to run a 70T rear only.
A 30T front and a 70T rear will give you a final drive of 3.1568:1
Changing the front motor sprocket and chain will give you pretty much the same thing with a final drive of 3.1625:1 for less money and a lot less work.
If you put a slightly taller tire such as the Michelin Commander II, you can end up with a final drive of 3.085:1 giving you 3012 rpm at 75 mph. With the stock Dunlop, you will turn 3088 rpm at 75 mph.
Plus you speedo remains accurate. If you go with the 70T rear pulley and 30T tranny pulley, your speedo will be off by about 13% which translates to reading 75 mph at 65mph.
The Evolution Industries 30T sprocket and chain set can be had for as little as $220 on Ebay
Thanks in advance.
