How snug should a full face helmet be?
I just ordered a fullface helmet off eBay by using their sizing chart and it seems really tight. I have not had a full face helmet in years but this seemed very restrictive and uncomfortable. Is this common, or should I send it back in and order the larger size?
Buying a helmet without trying it on is a hit-or-miss proposition. That said, the tighter it fits, the better. Obviously, if it's too tight to be worn comfortably that is not good, but generally speaking, the tighter the better.
A good test is to put the helmet on and move you head back-n-forth sharply. If you feel the helmet move or slide around, it's too big.
You want a snug fit on a new FF so it can give a little over the first several uses, but you don't want it so tight that it causes uncomfortable pressure. It's very subjective, but if you feel really wedged in, it's too small
I just ordered a new Bell half helmet. My measured size is right on the line between L and XL. I took a chance on the L but might be in the same situation as you. The good news is that I bought from Revzilla and their return process is very good.
Good luck. What helmet did you get?
Helmets are a difficult thing to order online because of the fitment factor. That being said, they should be pretty tight and snug. It should be snug to the point that it may be a bit annoying if you are standing around with it on. However, when you are riding and your mind is in other things, it should not be an issue. It should fit snugly on your cheeks and all the way around, particularly when they are brand new. They do require a bit of a break in period and will losen up some over time.
A few years ago Arai quit selling online for this very reason. Unfortunately they lost sales and started selling online again.
My advice is, go as snug as you can without giving yourself a brain wedgie. The break in will make it right in a fairly short time.
wish you spent the extra money.
