Dyno numbers on 107 build
Got my final tune Saturday on the Fuel Moto 107 with Woods 555.
105 HP and 115 Torque. Will post sheet in the next couple days. Rod's Performance in Hanceville, Al did the work. I am very pleased with the performance. Torque improvement is impressive. Rod said I could gain additional 5 on both HP and torque if I had a 2-1 exhaust. I am running V&H Big Shot Staggers with BCT Monster baffles. I like the sound too much for the extra numbers.
scan it, save it as a .jpg (or any image file) and upload it to your pic host. then do it like any other photo. also dont forget to put the sheet and build details in the dyno/ time slip thread too
to attach images (i use imageshack) look for the "get code for forum" link after you select the picture, copy the text in the box, and paste it here in the reply, and youre all set.
If you use photobubket, download the scan. Click in the photo/dyno sheet on th right had side it says image links, make sure it is opened. at the bottom it says IMG code. left click that and it will copy a direct link.
on The quick reply box right click and paste. then click on post quick reply, your done.
Aerocharger_Brad
Blowers/Turbos/Nitrous Oxide
29
10-10-2016 03:34 PM
