Rear Brake
Rear Brake
I posted this in the brakes section and didn't get much reponse so thought I would throw it in here and see how I go...
Just curious to know what everyone else's are like???? I have a 2010 Widey and the rear brakes are terrible,I doubt you could lock them up...I just changed pads to see if it made a difference but it didn't do much..Maybe a caliper and rotor change????
Cheers...Sparra
Cheers...Sparra
Strange like rawhide07 mine will lock up in a jiffy, I have to be careful not to lock them up and start skidding. Maybe your forward foot peg is blocking you from applying them properly. It happened to me when I changed pegs - the trick was just to rotate the peg a little and that was it.
On my SuperGlide with forward controls, I can barely even press the rear brake pedal. I have to turn my toes into the left to be able to even get my big toe on the pedal. I installed a larger pedal cover tonight but haven't been out to test it. I have got to put a backer plate on the pedal to strengthen the backing of the new pedal cover. So far I just use the front brake to stop as that is really all that I can apply. I too thought about changing the pads and bleeding the system but now to hear you all that doesn't do anything to help.
The brake rod is connected to the master cylinder. Not the reservoir.
Did you flush the system, change the fluid entirely in the brake system?
Does it feel spongy?
If not, I would blow out the brake line just to make sure something isn't interfering with the passing of the fluid.
It is possible the master cylinder is bad.
