Can't see my "N" or turn arrows flash.
I push the turn signal or I put the motorcycle in neutral. Unless I get close use my hand to cover outside light or it is dark I can't see the things light up. It is hard enough to find neutral on my bike. Not being able to see a green N doesn't help at all. I mean I can't even see it on a cloudy day.
Anyone know how I can make these lights brighter? Or maybe add something to the bike to take away the outside light so they can better be seen? Maybe a smoked plexi-glass can do it? Just everything on this display is dim except maybe the red oil light before bike is started.
Overall it is just a pain it the butt. Doesn't stop me from enjoying the bike though.
yup that, what year is your bike? there's no more bulbs, it's just a board now a days. then take it apart and clean it if it isn't burnt. I hope you have the manual, there is one little trick to get the board out of the socket.
The bike is a 2000. I am not the original owner obviously. I took the seat off awhile ago and found some custom wire work done for LED's. Not all of it was connected right if at all.
After I rewired them I noticed the lights are brighter for the display now. Still not as bright as I would like them to be but now it has me thinking I am still looking for a electrical problem.
Yes my Avatar is my bike and my plan will be to go over more of the wiring tomorrow. Especially the ground. I will look into new LED bulbs also TY.
I'm going to try the LED's. $3.50 ea.for the brightest. Good idea going the same colors as the lens/function color. Maybe I'll do the speedo & tach and be 100% LED.
Maybe I am just new to the site but I can't find a very high brightness LED bulb that looks like I can use it. Kind of late now. I will look more tomorrow I guess.
EDIT: Would this be it by chance? http://www.superbrightleds.com/morei...edge-base/201/ I seem limited if I want to go with green and these say indoor use recommended.
