Im moving my switch to the horn location and was thinking about doin with out the horn. Has anybody else just done away with the horn and if so do you regret it ?
I haven't had a horn in years. Never missed it. Anytime I thought about using the horn, it would have been after the fact just to draw attention to a middle finger like mentioned above.
When I did the DK Customs coil relocation kit, I mounted the new horn between the front down tubes, similar to the Blackline stock horn mount. Anyway, I never hooked the wire up and have not missed it at all.
Thought about not hooking is up but Virginia frowns on the no horn bit. Can't pass the state inspection. (See below)
19VAC30-70-380. Motorcycle horn.
INSPECT FOR AND REJECT IF:
1. Motorcycle is not equipped with a horn in good working order capable of emitting sound audible under normal conditions for a distance no less than 200 feet.
2. Horn is not mounted securely, wiring is defective, control button is not operating properly, or is not installed at a location readily accessible to the operator.
