Trailering my Dyna?
Trailering my Dyna?
Thoughts on an economical solution for a trailer so I can bring my ride along.
Lowe's has a 5x8 mesh trailer for $669. Can these support a motorcycle OK? The 12 inch tires seem a little small, but the payload capacity is well over the weight of my Dyna.
One of the reviewers mentioned hauling motorcycles without any issues.
Just wondering what my best and most economical options will be.
Thanks!
Thanks!
I have the same trailer but mine has the 13 inch wheels (I recommend larger wheels). I bought it at Tractor Supply for $649.
I have trailered my Street Bob on it between Martinsburg, WV and Myrtle Beach, SC (500+ miles each way) over 12 times without any issues and I don't even use a wheel chock for the front wheel. My Expedition pulls it like its not even back there, even at 80+ MPH on I-95. As a matter of fact, I will be trailering down to Myrtle Beach for the week of July 4th, next Friday!
I recommend the Daddy Mack tow straps. http://www.daddymack.net/index.html
http://www.google.com/url?sa=t&rct=j...48293060,d.dmg
I use 2 Daddy Mack straps on the front and some regular ratchet straps on the rear swingarm for stabilization. Only the 2 Daddy Macks are needed though.
Here is a pic I found from Summer 2011. I have a 6inch drop hitch to level it out.
Update: Don't worry about the naysayers. This trailer works fine for hauling a Dyna. I did cover the mesh floor with plywood but that is only because I use it to haul mulch for landscaping around my house. I store my trailer in my garage year round. I just push it to the furthest corner of the garage and store all the kids bikes and toys and snowblower on it when I am not using it. It has come in handy many times.
I have a trailer very similar to that one. 2 years ago (before I bought my Dyna) i used that trailer to haul 2 bikes on a 6 hour drive to Deals Gap. Th only issue we ran into all weekend was the flat tire on Sunday before we came back. Went to Tractor Supply, bought a new wheel and tire, made it home fine and ended up with a spare!
Received 4,309 Likes
do some research and you may find a better trailer about the same costs.
There is a trailer sales a few miles from me and you can get a 5x10 with drop down ramp with 15inch tires for under $700. these are one of the best trailers I have ever used.
I traded my 5x10 for a 7x12 and it will hold 2 bikes easy or 3 if one is on backwards.
I use a regular tie down on the rear and wrap it around the wheel and ratchet it firm. This will aid in not having to worry about the front tire being firmly in place. The bike is supported in every direction this way. I use soft tie downs from Harley.
I also use a 4x6 block of wood and place it under the frame so the forks doesn't bottom out. If the forks are bottomed you are putting pressure on the fork bushing which can and will cause the seals to leak.
Guess it is up to the individual what kind of trailer you want, but for me I spent a little bit more and got a enclosed 5x10 and bought the Lock-N-Load wheel chock. It secures the front of the bike snuggly without putting unneeded pressure on the fork seals. All the way to Florida and back with out any slippage and the bike was clean and ready to ride once there.
