problem with throttle grip/cables
I am having a problem with my throttle grip and or cables on my 06 street bob. when my bike is off my throttle has the correct amount of freeplay and when you twist and release it springs back to where it should. when the bike is running and you twist the throttle and release it springs back to where it should but you can twist it back another half a turn. so when you grab for the brake or slow down your hand naturally turns the throttle grip past where it should stop and then when you go to twist the throttle again it doesnt grab where it should, it takes that half a turn plus the amount of freeplay before any gas is actually applied and makes it a little sketchy especially with a passenger or when you or taking off uphill. Anyone have any ideas? I have a 16' ape setup with burly cables but this problem also occured when my setup was stock. thanks
When the throttle rolled back the way it was suppose to in all directions on each cable I have very little free play left. Actually I would prefer just a bit more free play, but it is better than too much free play so I am leaving it as is.
mine does exactly what it should when bike is off. so it seems adjusted properly. but when running the throttle snaps back to its closed position like normal when bike was off, but then can be twisted back more(about half a turn) with your wrist. so when you roll off the throttle and grab the front brake, the next time you go for the gas you have a little more than this half turn before there is any throttle response.
I have a 14" apes and a 14" burly cable kit which is actually too long and there is a fine line between me having a lot of play in the throttle to where it is now with virtually no play.
The only thing I could think of bro is to start the bike and turn it left and right to make sure your idle rpm's dont change to totally rule out the adjustment issue.
Good luck!
First thing is to check your star nut under the grip, it is there to lock the throttle have you made sure it's completely loose? Are you running a tuner on your bike?
Re-reading your post it sounds like maybe you did not get one of the cables fully into the plastic guide on the inside of the grip.
