brake pads?
I just replaced my front brake disk and went with new OEM pads (p/n 44082-00C).
The 2003 Dyna Models Service manual is your friend.
Here's a link to the Instruction Sheet that came with the new pads.
My pleasure....
I bought Lyndall pads for my bike. 7195 Gold +. Same pads for both front & rear.
Added: Motorcycle Metal is a forum sponsor. If you click on that link, then click on the Dyna section, scroll down to 'braking' you will find some great info on changing pads.
Lyndall pads are vastly better than stock. I haven't tried the HD replacement pads but assume they are the same as the factory delivered pads. The HD pads work well after break-in, but you'll notice a big difference with Lyndall.
Talk to HogPro here on the forum or at their website. http://www.hogpro.com Robert will help you.
This is how I did it...
Front: Pull the caliper off, take out the 2 pad retainer bolts (12 point) and take out the pads. Compress the pistons and install the new pads. Put the retainer bolts back in and reinstall the caliper. Torque to specs. If you do not open the system, you should not have to bleed it.
Rear: Take out the two pad retainer bolts (8mm 12 point) and pull out the pads. Compress the pistons taking care not to damage the rotor and install the new pads, reinstall the pins and torque to specs. If you do not open the system, you should not have to bleed it.
Of course, Murphy's Law is in full effect anytime you work on a Harley Davidson...or an airplane.
