Fat Bob saddlebags
Old 12-30-2014, 04:46 PM
JMC22's Avatar
JMC22
JMC22 is offline
I used a simple piece of 1/4" x 1" x 8" long of aluminum bar stock I got at Home Dept, drilled out a few holes and relocated my turn signals to just past the struts - pretty simple and I then put on full size Heritage bags
Attached Thumbnails Fat Bob saddlebags-imag0569.jpg   Fat Bob saddlebags-imag0570.jpg   Fat Bob saddlebags-imag0572.jpg
  #32
Old 12-30-2014, 05:23 PM
target64's Avatar
target64
target64 is offline
Originally Posted by Devchonachko
How much can you fit in there? For instance, would I be able to put some groceries in there, like a gallon of milk and other heavy stuff? I checked out the website, they seem pretty good, and I like that I wouldn't have to relocate my turn signals.
bag will hold two gallons of milk or water and can fit in a small loaf of raisin bread. on the left side holds my heavy riding jacket and gloves extra glasses, and some cleaning stuff. the other side bag holds chaps and my akoury helmet and has room for some extra. and all my stuff stays dry and its lockable.
  #33
Old 04-27-2015, 10:53 PM
ChromeBlows's Avatar
ChromeBlows
ChromeBlows is offline
  #34
Old 04-28-2015, 12:38 PM
Shizims's Avatar
Shizims
Shizims is offline
I just put a set of Leatherlyke hard bags on my '08 Fatbob. Love them, easy install, sleek contemporary look (without all the studs and do-dads). Very Roomy, padding on the inside. Bolt right up with perfect cut outs for the shocks and turn signals. Install very tight with or without the Detachable hardware. $489.
  #35
Old 04-29-2015, 04:37 PM
bsljacques's Avatar
bsljacques
bsljacques is offline
I have some Viking Hard bags on mine and they work pretty good! Don't have them on there all the time...just when I need them.
I use some easy brackets. On the install I did one bag at a time as both bags were not quite the same size on the back side (off by 1/4" or so). But it came out rather well. Check out the pics!
Attached Thumbnails Fat Bob saddlebags-fatbobbag1.jpg   Fat Bob saddlebags-fatbobbag2.jpg
  #36
Old 05-01-2015, 02:17 AM
Wilburcat's Avatar
Wilburcat
Wilburcat is offline
I put Boss bags on mine, defenately recommend them. They lock on with a latching mechanism, on and of in 5 seconds. You can stand on them and you can use a padlock to keep folks out. I paid $800 4 years ago, but worth every penny. Check them out.
  #37
Old 05-01-2015, 05:24 PM
Fatbob bagger's Avatar
Fatbob bagger
Fatbob bagger is offline
Got a nice used set of hard bags from a classic. Used the front holes and redrilled the rear holes. Took out the quick attatch back rest bolts and bolted straight tgrough to the struts. Super solid.
Jpatterson317
03-28-2018 07:06 PM
Rikus
04-11-2017 02:06 PM
gseely
01-01-2010 10:28 AM
gseely
12-17-2009 12:51 PM
Harley_RN
12-28-2008 05:15 PM
Quick Reply: Fat Bob saddlebags
