crazy question about FXDWG front end.
If you were sure there was no way, then you wouldn't have asked now would you?
I installed a 2000 Wide Glide front end on my 2005 Super Glide, bolted right in! Compatibility in front ends isn't that much of a hassle within the same family of models, at least in the earlier years.
It would certainly help if you provided more data...year of your bike, year of the front end you'd like to install, etc.
your bike has a 32 degree neck , therefore if you did install a different front end as you suggested like a streetbob or fxr you would need longer fork tubes due to the rake , or leave as is and it would lower the front of the bike if that's what you want. but pretty much any front ends with a 1 inch stem will work, in fact I installed a night train front frk on mine with a little grinding of the fork stops
I am sure that it would be possible.. as the swap the other way... I.E. Wideglide front end on a Dyna bob /Superglide custom etc.. is a popular mod. What year is your wideglide? It may be as simple as swapping trees for you.. but remember your wideglide runs a stock 21 inch front wheel not a 19.. I have '12 FXDC with 49mm forks and am considering doing a swap to wideglide trees.. if you have a newer WG say a '10 or newer.. I might be interested in a tree swap..
I have also heard that there is a certain amount of rake in the WG frame.. say 2 degrees or so.. outside of what the trees also have.. you will take some rake out of the equasion by switching to say superglide trees but the neck of your frame is still raked a bit..
I am looking to do the wide glide legs on my '10 FXDF, and the 2010+ wide glide has a fork that is only 1" longer than the other Dynas. That FXDWG leg # is 48862-10 and I'm thinking that should be a nice swap in.
If you found any additional info let me know. I work at a Harley dealer myself and I'm working the technical resources at my disposal, but don't have exact lengths on that Wide glide leg so I'm pausing for more info.
