i'd give myself about 10 minutes before i accidentally kicked that.
It actually isn't in the way at all.
This pic shows the connectors for the signals in the wiring harness (white for left, black for right). If you buy the signal relocation kit from Harley you get connectors.
since I didn't buy the kit I had to solder. I cut the connectors off, soldered on wire extensions then soldered them to the signals.
I cut the signals off the wires on the handles, shrink wrapped the tails and stuffed them into the handlebars. After I removed the signal brackets from the bottom off the mirrors the stem was too long for the nut so I had to trim it down a bit.
