Charging system 16.9V, YUCK!
Beautiful day here, took my bob for a 250 miles ride. On my way back, the charging system shows 16.9V when I am cruising. It drops to 13.6V at a light. Would it be the voltage regulator? How do I check this problem with a multimeter? Hopefully I didn't cook the battery lol.
Based on the motorcycle volt meter, it sounds like a classic voltage regulator failure...BUT...make sure you have a charging problem before you start changing things...read the volts at the battery terminals with your voltmeter...should be ~12.5 vdc cold, ~10 vdc when cranking, and ~13.5 vdc running. Engine RPM will affect the charging volts some, but not more than a half volt or so. If you have these voltage reading at the battery during these three cycles, then the problem is something else with the bike's volts indicator system.
Received 4,309 Likes
Start your bike and check voltage across the terminals of the battery, idle could be 13.5v and above 2000 rpm the voltage for a fuel injected bike would be between 14.2-14.5v. The HD gauges sometimes aren't that accurate. If your voltage goes above 14.5 to 16 v it's time for a new reg.
Do NOT trust the HD voltmeter...get a digital multimeter and check the system volts at the battery terminals...if that also shows high voltage, then you may have a stator issue...
To check the stator, you will need to disconnect the voltage regulator plug and check across the pins for continuity (shorted) and then from each pin to chassis ground for infinity (open). If this checks good, then crank it up, and read the AC voltage across the pins coming from the stator. The volts should be 36-46 vac that should vary with RPM.
If these checks are all good, then your battery may not be putting enough of a resistance load on the system, although that is rare...
