Which exhaust for Merck/Zippers 131
Looking to change exhaust system as the one I have keeps cracking and I keep fixing it or the mounting bracket.
What are my option?
What do you recommend?
At the port I have 2"ID at the moment the bike is pulling 164hp...
Looking for something almost off the shelf before building another custom one.
Thx
Joe
DEFAB
This image has been resized. Click this bar to view the full image.
Report this image
What are my option?
Thx
Joe
DEFAB
Report this image
It's going to be very hard to find an off the shelf exhaust for a dyna that will support that much motor. I think your best bet, and cheapest, and closest to what you have would be some 2" cycle shack phd-232. They perform really well and can be had for less than $300. But will just any exhaust fit with that motor and flange at the head? Might have to be modified.
What I am seeing is a lot of the manufacturers are marketing pipes for "Big inch, Hi-comp" engines etc.. but those are 1 3/4 tapered pipes. The Bassani B1 recommended is very attractive.
Has anyone run a Big inch motor (124" +) with 1 3/4" at the port?
I have a Pro pipe sitting that I can modify to work , would just like some feedback on the sizing of the pipe if anyone has used this size exhaust on a "large inch motor". The Pro pipe is also a tapered 1 3/4 like the Bassani.
Joe
A D&D Borezilla will work, and for the creme' de la creme' check out the Guppy pipe at www.jbvracing.com.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Scott
Scott
Forget the RB.
Jbco2, do you have a dyno sheet of where the bike is now? Can you give more info on the motor? Sounds pretty stout.
