Ricor Intiminators with Traxxion Straight Rate Springs
Old 05-03-2014, 08:40 PM
rooti's Avatar
rooti
rooti is offline
I have a stock FXDC chrome clamp.
  #982
Old 05-03-2014, 10:17 PM
Silvio's Avatar
Silvio
Silvio is offline
I tightened down the Speed Merchant preload adjusters one more band. This put them about 62% in. I'm not sure how that relates to the previous sag figures with them 50% out. I did not put the bike back on the lift and measure. Next time the bike's in the air, I'll do that.
I also tightened--lessened the sag--by one turn my Ricor rear shocks.
And I went for a ride on some of my favorite roads with bumps and curves.
There is no question that the response is dramatically improved. I will keep fiddling with it to get it the best possible, but I'm really happy with the suspension's current performance.
Overall, I would say that a lot of the differences are really subtle. As a new rider, I might be having some trouble identifying the changes. What I experienced on the milled road could be a matter of my expectations being too high. That section is a pretty rough patch, and it might just be too much for any suspension to solidly handle (I should get a pic or two and throw it up here for reference).
I am looking into the steering head bearings as rooti suggested, and am gathering information. I started another thread on it to avoid hijacking this one.
https://www.hdforums.com/forum/dyna-...quesitons.html
As of now, I'm happy with the results. I need some more time to tune it all in and to see if I can get it any better, but it's definitely moving in the right direction.
  #983
Old 05-03-2014, 10:28 PM
b2inUT's Avatar
b2inUT
b2inUT is offline
Assuming you're talking to me, rooti... I've got a lead on one. I'll let you know if that falls through. Thanks.
  #984
Old 05-05-2014, 12:44 PM
murrayliving's Avatar
murrayliving
murrayliving is offline
.......holy Toledo.....
http://www.racetech.com/page/id/146
  #985
Old 05-05-2014, 02:29 PM
rooti's Avatar
rooti
rooti is offline
Hey Silvio, I think you are headed in the right direction. I initially have never been instantly satisfied with any of the suspension mods I have done. It takes adjustments to get everything right. Then one day you go out for an all day ride and it hits you...man this is sweet. When you hear one after another raving about how great the mods are you expect some kind of miracle suspension where it turns all bad roads into good roads. The reality is the bad roads are still bad.
I didn't realize that you were a relatively new rider. The suspension work you do now will be more realized when you really start pushing the bike. It will also give you the confidence to trust what it will do. I had two bad experiences with the stock suspension with my wife on the back. One was in a corner I took real tight...felt like the back tire was going to wash out on me. So bad I pulled over and checked the tire pressure before going on. And the second was a bad bump that damn near launched her off the back. (the person riding behind me said she came a foot off the seat) So the suspension upgrades help take some of the spookyness out.
I have one loop ride I use for testing. I've done this same road probably a hundred times so I get a pretty good idea of how the changes are working. I think you will be surprised when you go out on a all day ride. I went with my wife on the back saturday and we got into some pretty good corners and even caught air once.
It was rock solid...but that was after the 4th time of taking it apart and putting it back together. Just be glad you didn't have to get a lighter spring..to think I almost didn't go through the trouble...made the difference for me.
  #986
Old 05-20-2014, 09:59 AM
monster715's Avatar
monster715
monster715 is offline
Great way to start my Tuesday.. Came out this morning to a nice little wet spot on the garage floor under the right fork leg... Only been about 4k miles since I did the traxxion/ricor install and I rebuilt the lowers with the Harley kit when I did it. Looks like the crush washer is leaking even tho everything was torqued to spec.. Anyone had issues with this? I'll get it on the lift this weekend and find out for sure but I'm almost positive that's what's leaking. Looks like I get to take it apart again, thought I nailed it the first time around dammit!
  #987
Old 05-20-2014, 10:31 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Don't feel bad, monster.
Seems my seals are leaking...again.
I might just say eff it and order the new monotube kit from progressive since it's finally available.
  #988
Old 05-20-2014, 04:32 PM
monster715's Avatar
monster715
Now that I look again both sides are wet.. Wtf how could they both be leaking already ? Guess I need to order more shock therapy and a couple more Chinese washers...
  #989
Old 07-27-2014, 08:21 PM
rsking45's Avatar
rsking45
rsking45 is offline
I finally ordered my springs which are 44x380x.90 .Yesterday I installed the springs and the ricors. I spent a few hours tying to get the correct amount of sag.Spacer lengths from 5-8 inch spacers and can not get the correct sag.I tried spacers starting lust below the treads inside the tubes to .5 above the tubes.Its better with the longer spacer but I can only get 1 in of sag. I gave up because my fingers ache and had enough of taking it apart putting it back together and repeat
  #990
Old 07-28-2014, 11:55 AM
WMX124's Avatar
WMX124
WMX124 is offline
Are you sure you're measuring the sag correctly?
Quick Reply: Ricor Intiminators with Traxxion Straight Rate Springs
