Ricor Intiminators with Traxxion Straight Rate Springs
Ricor Intiminators with Traxxion Springs
I ordered a set of Ricor Intiminators and a pair of Traxxion springs to go with them. After reading numerous posts online as well as reading Howard's (Motorcycle Metal) dislike of progressive wound springs, decided the extra wait would be worth the straight wound ones.
Plan is to use amsoil 10w fork oil as well, based on Ricor's recommendation.
If you are running this set up how do you like it and was it a big improvement over Progressive's progressive springs? Any tips or recommendations on setting the spacer length for preload?
Thanks
Thanks
Yep:
https://www.hdforums.com/forum/dyna-...upgrade-5.html
My journey started around post #160 or so.
I'm waiting on a set of .90kg single rate springs from Dan now. The 1.0kg were too stiff for my 160lbs.
I also switched back to Amsoil #10 from #5 after conferring with Brian at Ricor about what I was feeling in the front end.
I put the stock progressive wound springs back in until the .90kgs arrive.
I can tell you that the #10 Amsoil has a much more stable feel at high (over 80mph) speed, but the #5 provides a nicer ride at lower speeds, with the stock springs. I can't wait to see how things go with the .90kg and #10 Amsoil.
Also, I'm using RSD preload adjusters, so my spacer length isn't as critical as it would be for someone just using the stock fork caps. My goal is to get the sag perfect with the adjusters at the midway setting so I can soften or tighten things up as necessary.
I'm glad you're doing this. I won't be the only guinea pig.
I'll post my spacer measurements with the new springs as soon as they get here.
Dan convinced me to go with the 1.0kg despite my concern that I didn't weigh enough. He said he was 170ish and the 1.0kg was a "plush" ride for him (on a sport bike). He freely admitted not having a lot of working knowledge about our 49mm set up and offered no cost exchanges if I didn't like the springs. He's been pretty helpful even he didn't quite understand what I was trying to do at first (which is basically copy fabrik8r's work in the touring section). Considering the riding position on a sport bike, the 1.0kg probably would be plush since more of the rider's weight is over the forks. Just didn't work out well on a Dyna.
It took about 2 weeks to get the first set. It's going on 10 days now waiting for the .90kg.
Did they meantime charging more because the spring is "custom"? Rather than the standard price?
Damnit you guys, now I'm going to be wanting to do shocks & springs next...lol!
What are you running on the rear of your bike Rooti? I know you've got Ricors, but give me details.
I know winter is coming here soon, which brings some downtime, which leads to boredom & thinking, which ultimately leads to me spending $ on the bike..
