Wide Glide Rake Angle Misunderstood Help!
It seems as though the general belief is that the wide glide rake is increased by 5 degrees or so by the steering head and a couple more by the triple trees. I may be off a little in the exacts, but my problem is that I bought a wide glide triple for my super glide and I see that it actually has a NEGATIVE rake to it. My belief is that Harley put a lot of pos angle in the head of the WG then backed it off with the trees a little maybe for trail reasons. Anyway is this going to screw up my super glide to fat bob conversion? Has any one used these triple trees on a super glide and will it handle poorly?
My 2007 WG has 34* in the neck and *2 in the trees for a total of 36* rake. Stock, from the Moco as delivered to the dealer.
The holes are supposed to be lined up....if they weren't, you couldnt get the tubes in . The difference is between the angle of the tubes and the neck shaft. You should be able to measure the distance from the centerline of the forks to the center line of the shaft, on the top of the upper T-tree. then do the same on the bottom of the lower tree. The measurement on the bottom of the lower tree will be the same or greater. that would be a zero or positive rake addition. it could only be negative, if the bottom measurement was smaller.
See pic: (The lower tree is shown on top)
Here is a good page that explains how it works... http://www.seegercycle.com/Rake-and-Trail.aspx
I believe, at least on mine that the trees are 2 1/2° over what a standard Dyna is. I am going to add 3° of rake with offset steering arm bearings. This is just like chopping the frame so it won't mess with the trail. You might look into this too. Vulcan engineering makes them for just about any bike out there. Just a suggestion. These kits are a lot cheaper than buying raked trees as well.
