Dyna lights!
I used a 30A relay and a fuse, no probs for the last 2 years. I'd suggest to turn the aux light on and off while the engine is running so you don't drain the battery while the engine is not charging it and to still give as much power to the starter motor as possible.
Generally speaking, most H-D models have a 32 AMP electrical system.
Here's how to calculate your power consumption:
volt X amp = watt
so
watt / V = amp
for the passing lights: 110 / 12 = 9.1 amp
Headlight takes 55 watt = 4.6 amp
Running lights take 5 watt each = 0.8 amp
Directional lights take 21 watt each = 3.5 amp
Brake light takes 21 watt = 1.75 amp
Rear light takes 5 watt = 0.42 amp
Etc.
With a 32 amp system you will be good.
Here's a passing lights wiring diagram.
Some options:
1. To run passing lights independently: splice battery + or ignition switch powered 12 v wire to switch in diagram
2. To run passing lights with low beam: splice low beam 12 v feed wire to switch in diagram
3. To run passing lights with high beam: splice high beam 12 v feed wire to switch in diagram
You're welcome.
Some additions:
For option 1 either connect to the battery + pole or use one of the the orange/red wires from the accessory plug (pin 1 or 3) under the seat (see image below for the plug parts to use)
For option 2 use the yellow low beam wire in the headlight bucket;
For option 3 use the white high beam wire in the headlight bucket
Some additions:
Damn!!! That is exactly what i was planning on doing. I was so stoked on doing that because I have never seen in done before. Well now I may have to reconsider... maybe i'll mount them where the forward controls would go, or maybe even on the bottom of my T bars. Hmm...
