Bike pulls
Bike pulls
This is a weird one that I have never experienced before. On a run with friends last weekend and we all pulled up to a light with a hot rod Camaro in the next lane. We got into a bit of a rev out to see who had the loudest pipes with the Camaro. I was holding in the clutch and the bike started pulling forward. Kinda creepy. I have been using Drag Specialty Primary oil and Adjust the clutch and cable when it needs it. I have no idea what would cause it to pull like that. I have had a couple indie shops tell me it's ok to use synthetic in the primary, but I have also had certified techs say synthetics will make the clutch slip and to use HD Primary/Tranny or petro based. Any opinions?
How many miles has the bike done? Serviced regularly? There is an adjustment possible on the clutch release basket due at certain intervals that could cause what you've experienced, but sometimes techs take the easy way out & just adjust the cable. (They did on mine anyway).
A wet clutch behaves differently to a dry plate such as a car, but it shouldn't ever creep forward.
Can't hurt then to check the release adjustment. Should be about half a turn out if I recall correctly. The way I understand it is worn clutches are more prone to slipping under torque (not gripping enough), but if you experience the opposite (not releasing enough) that's usually an adjustment issue.
