How to turn off head light 2013 Street Bob
Where is the fuse for the head light. All I could find is two fuses in left side cover below seat. Called P and A and Battery. Removal of which did not turn off head light when I turned on ignition . I do have service manual but could not find.
Have to install and program tuner and want to turn off head light to conserve battery.
Thanks,
roger
Thanks,
roger
Thanks,
Roger
The 12v power for your headlights comes from the Body Control Module (BCM). The wire colors are blue/yellow for low beam and blue/white for hifg beam.
The BCM gets its 12v power from the battery through the 40 amp main fuse.
I'd recommend to unplug the 4 pin headlight connector or remove the bulb from the fitting.
My thoughts exactly. I had to replace my ignition module yesterday, and it's a 40-50 minute process where the bike has to be on for long intervals, draining the battery. I used a tender and it all turned out fine.
Thanks,
Roger
