stripped primary case drain bolt...suggestions please?
11-15-2013, 03:15 PM
My Dyna's primary case drain bolt is officially stripped. It was a 3/16 hex but the edges are rounded out. Any suggestions on how to remove it and replace it? Thanks for chiming in!
11-15-2013, 03:19 PM
11-15-2013, 03:24 PM
Get an easy out or a left handed drill bit.
11-15-2013, 03:39 PM
11-15-2013, 03:42 PM
Tack weld a tool to the drain plug, it may not be the ideal method, but it will work. Make sure you dont have any fuel leaks around the work area.
11-15-2013, 03:44 PM
Quote:
Originally Posted by
Rootro
Tack weld a tool to the drain plug, its not be the ideal method, but it will work. Make sure you dont have any fuel leaks around the work area.
...and that at least the negative battery terminal is disconnected.
I think I have an easy out equivalent lying around...gimme a minute...
soft 02
What he said. Your best solution. Done it before more than once.
11-15-2013, 03:45 PM
Rootro
If you do this, make sure to disconnect battery and ecm.
11-15-2013, 03:54 PM
You could try hammering in a large flat end screwdriver or a torx to get the bolt out...
11-15-2013, 03:59 PM
Robbie13
I just replaced my ignition module/ecm this week! I think I'll take the easy way out...get it?
no? ok...
