2003 WG engine upgrade questions.
FYI.. I have very little to no knowledge of engine upgrades so I am hoping I can get some direction here.
I have been thinking about doing some engine upgrades since I got my WG earlier this year. I originally was just going to do a cam upgrade where I was going use a Andrews 26N. After doing some more reading I figured I would do a little more if I was already going to be digging into the engine. My plan is to get my original Jugs bored to 95", get the SE 95" cast pistons and add a new Cam with the complete cam/cam tensioner kit from Andrews
so, I have a few questions involving that.
1) Is there anything else that I will need to complete this upgrade?
2) Where can I find the bigger pistons at a relatively good price? (or do you have a better suggestions)
3) about how much does it cost to get the Jugs bored? (anyone know of any places in Northern Illinois?)
4) would the 26N still be a good fit with the 95" as it would have been with the 88? I want low-mid torque.
If any of you can answer any of these questions I would greatly appreciate it.
Thanks!!
Thanks!!
As alluded to by MCCHP, the cam swap and big bore upgrades won't do so much if you're not getting more air into the engine, and out of the engine. To do that, you'll need to install high flow air cleaner and exhaust. There are many choices when it comes to these two upgrades. You will also need some type of tuning device. There are several of these available too. I'd suggest you start reading the upgrade lists in other members signatures and then finding threads that discuss these upgrades. You'll learn a lot.
i WOULD RECOMMEND A DYNOJET THUNDERSLIDE JET KIT
I guess I should have mentioned this in my initial post, but I already have the Stage 1 big sucker air filter (which I plan to change to the KNN Air charger for more knee clearance) and I also have V & H straight shots. What type of tuning device is used on a carbureted bike? I thought those were mostly used for EFI bikes? I could be totally wrong on that though. Thanks for the tips this far.
@aces&8s so you are recommending I go with the 88in Wiseco 10.1 piston instead of boring out to 95" and getting the bigger piston? I don't know much about this, but would that add a significant amount of added power and give room for additional upgrades down the road? I'm definitely open to this.
@two lane tramp: After a lot of research I found that it is MUCH cheaper to just buy the bigger SE cast piston(150$est) an get it bored out (150-175$ est) then to buy the complete kit. I also read that by boring your own cylinders you will have a more true fit.
If I am not correct with that statement please let me know, but I have read that a few times I think.
@aces&8s so you are recommending I go with the 88in Wiseco 10.5 piston instead of boring out to 95" and getting the bigger piston? I don't know much about this, but would that add a significant amount of added power and give room for additional upgrades down the road? I'm definitely open to this.
Your 88" built properly will get you easily 95+ hp and all the white knuckles you need. Without taking all the metal out of your cylinders. Put that Extra cash in building your heads and other go fast goodies... Which goes back to a proper kit that makes it all work together.... Call "fuel MOTO" or "Branch heads" for a proper kit. PS. Forged 10.1 weisco...
