Has anyone installed these on their dynas? I just installed them on my 08 fxdb and these f#*#$3rs are not working. They worked fine when I wired them and tested them prior to install. Once I mounted them they don't turn on. I checked with a test light and there seems to be no power to the connector that goes to mirror. The other connector on y-harness works fine. I'm pissed and feel stupid spending 300 on these.
Not me personally no, but there are a few guys I've seen running them on here. If they were working fine before you fitted them then I would double check all your connections. Or progressively uninstall them up to the point where they start working again like you had it & you will have found your problem. Keep us updated.
I have em on mine, I didn't use the wiring harness tho, I just wired em straight to the stock turn signal wires after I removed the bullets. Works great, very easy.
I'd just retrace your wires
I ran them for a while with the same setup. No harness because I removed the bullets. Power to the mirror and grounded to the fastener where it installs to the lever housing. The Y-Harness is only needed if you are running them with the normal TS in place.
I bought this little doodad called a blinker genie. Its about the size of a dime and it allows you to use the run/turn combo. You just splice it in between the mirrors and the old TS's.
they were a pain to install but worked find for me… just take your time and check you've got the pins/plugs the right way round and work up from there!
Well fellas it looks like I wasn't carefull when I tighten them and exposed the lead wire causing a short. Got them traded under warranty and got them running. I gotta say I love em.
