Best 95" Kit
mud (03-05-2020)
That's the thing. Bore alone won't give the best bang for the buck. Talk to Joe The Powder Pro (User JRK something something something). He's got a hot 95, runs it hard and has had it for a good long time. He'll have a good recommendation for you.
User VDOP is into so e heavy drag racing and know the best builders too.
jbob208,
Where in Nebraska are you? If you're in the western part of the state, you might want to consider taking your bike to Sangers Cycles in Fort Collins, Colorado. This is really a top notch indy shop where the folks really know how to get the most out of your upgrades. I too have an 05 FXDLi and Sangers handled the 95" upgrade, cams, and head work (they send the heads to 10 Litre Performance). This bike runs very strong. See the numbers in my sig line.
I know Sangers recently did some engine upgrades on a father's and son's bikes, both of whom are from Nebraska.
In any event, there are lot's of good shops out there who can do this kindy of work but I figured I recommend one place that may be within your driving radius, depending on where in Nebraska you live.
I run a 95, solid, i have never been a fan of KIT builds as i wanted something to be built around my riding style not off the shelf. WFO Larry did my heads and my crank, the rest of the specs are in my signature below. I built mine to be a 1/4 mile ripper and still have the ability to get on the highway and roll at 80 all day long. bike has power everywhere... ill see if i can dig up my dyno sheets i know they where on here in the past
JMB79 I'm located in the Grand Island area, but Colo Springs could be a possibility. you and JRK5892 Sound like you have the build I am looking for, I would like to find a quality shop to do the work (I have known of 1 shop that used battery acid to lock crank nuts) so any reccomended GOOD shops are appreciated.
Like everyone I want power and dependibility. One area shop uses a kit (heads and jugs) from a guy on ebay to do the conversion and has had good luck. I need somthing that can be a daily rider that won't give me fits at 20 degrees for daily commute but won't burn up in 105 degree trips across country
In the three months since the work on my bike was completed, it has been my daily driver except when ice was on the ground. I've started the bike and driven it temps approachingn 0 degrees Fahrenheit and it's never stumbled or stuttered. Haven't run it in hot weather yet but I don't anticipate any trouble. Sangers has been building performance engines for a long time. They know what they're doing.
Actually, Sangers is in Fort Collins, not Colorado Springs. Fort Collins is 100 miles closer to you than Colorado Springs is.
There are, of course, many variables that go into final price. For example, yes or no on headwork, what cams are you going with, will you switch to gear driven cams, etc.
That said, for a 95" big bore with heads and cams, plus a Power Commander V and a dyno tune, you're probably looking at $3,000 to $4,000. I actually cannot remember the exact price (I'm probably repressing it). Give them a call and speak with Kevin, the owner. (970) 419-5500.
This all assumes that you already have high flowing exhaust and air cleaner installed.
