Idle??
Not sure how this would happen. The idle speed is set by the ECM and it should stay that way until it's changed electronically, either by a dealer or tuning device.
Higher rpm levels on a FI bike when cold is very normal.
If you turn the engine off before it idles down to normal rpm's with will effect the idle rpm's. The computer will think the higher rpm is the normal rpm thus have a higher rpm.
If that makes sense.
Let the engine get to the normal idle before cutting it off.
However after warm up to operating temps it should drop the idle to normal.
Unless you have a digital tach I doubt you can really tell the exact rpm any way.
