alloy art strut signals how did you route the wires?
I just got a set of the alloy art DSL83R strut signals and see no way to route the wires between the signal housing and the strut covers without shearing them off after everything is tightened down. if someone who has these installed could offer some advice, I would be grateful. They are going on a 2007 street bob with detachable hardware.
Thanks,
Pete
Thanks,
Pete
I don't have any personal experience with these lights but did just take a look at Alloy Art's website and pictures of the strut lights. I've got to admit that the website leaves a lot to be desired in terms of explaining the product. I guess they didn't come with instruction, huh?
From the website photos, it appears that you should first run the wires from the light through the rear most hole in the strut, then slip the part over the end of the strut, and run your bolt through the hole in the light and the second hole in the strut. Is the problem that you are experiencing that the wires a squished between the strut and inside of the light housing? Maybe the lights you received aren't sized to spec?
http://www.alloyart.com/dynastrutlights.html
Sorry that I can't help more.
I did not take any pics when I installed them on my 09 Street Bob. What jmb has described is how I installed them. There was enough room behind the light and the strut to avoid crimping the wires when I tightened the bolt down. I have the quick disconnect set up as well.
I am attaching pics of the signals. First is installed. The second two are views after I took the turn signal off to show the routing of the wire. I did not route wire through the hole in the strut. I ran it under the strut. There is room beneath the strut because I have the luggage rack support between the strut and fender. The wire fits beneath the signal cover with out a problem.
Thinking about buying these from alloy art. Curious to see if you guys are happy with them. I have a 2010 SB with no strut covers. Can I simply cut wire from my existing bullet lights and solder to these units? Would I need to get a special module so that I don't have fast blinking turn signals? I don't have that problem now and I do have LED bulbs in my bullet signals so I assume the previous owner installed one ..
thanks
thanks
