Year vs. Mileage
I'm with SLV for similar reasons. Both are nice bikes, but 2002 was the last year of the forged HD cranks before they outsourced them to China in 2003. CV carb bikes are nice for just changing jets rather than buying a fuel managment system as you make upgrades, and the 2001 bike still had the Timken bearings on the left side of the case rather than the roller bearings that they moved to in 2003 (no pun intended on the "moved" word, although roller bearing setups do tend to add to the runout problems).
Again, both nice bikes with low mileage and each have their pros and cons. I just prefer the things mentioned above if I have a choice - which is why I recently bought a 2002 Fatboy to add to the stable. Heck, I even put CV carbs on all my Shovel and Pan projects...
2001 sounds good except the mileage.
3,500 miles in 13 years would have me concerned.
Sitting that long a lot of things would have to be replace. Possibly a engine rebuild may take place in a short time. A lot of seals has dried and may need to be corrected.
Now if you are planing a engine build that would be different.
Fork seals, fork oil, swing arm bushings(maybe), all fluids , tires, carb work etcc. needs to be considered. Unless I get a super deal on one that old with that few of miles as it is I would consider the 07.
