fxdx fork oil service???
howdy riders i have a few questions,I have a 2005 super glide sport with 28,000 miles and want to change fork oil (cartridge style).Doe's this take any special tools or do you just take it off the bike and dump it and re service? I have a clymer and it doesn't really say much,just that some disassembly is required,then it goes through the whole rebuild process of the fork.Also if i found a factory service manual will it go through the whole service process in more detail than the clymer? Any help would be appreciated i really don't like taking my vehicles to a shop like to trust my own hands to do the wrenching. safe riding
There is a better way and it doesn't require taking off the fork legs. I use a vacuum tank called the "top sider" that I bought from a marine supply store. Just stick the plastic hose down the tubes and suck it out, and clean the inside of them with some clean rags. A heck of a lot easier than taking everything off.
To change oil you need a lift and either the special oil level tool or a turkey baster . My bike has drain plugs on the forks making everything easier. The tool is to set the oil level and works as follows: You set the desired level on the tool, pour in oil and slightly overfill, insert tool and use it's hand pump to suck out excess oil, repeat on other fork. I decided not to buy the tool for a single use and filled by volume. However, as the forks then felt too stiff, I used my trusty old turkey baster (been in my tool box for years for similar uses) to suck out some oil. Done.
With a 2005 I would do a complete dissaembly as it may contain sludge.
Get the manual, fill to proper level.
It's not hard to do.
When I did mine first I over filled it and had to suck some out. Mine was 4 inches from the top of the tube . est 26 ounces.
Get the book if your going to do it yourself.
Thank you all for fast reply,all are good info to me,as i've never replaced it since i owned it at 7000 miles,so factory oil is most likely still in them.Probably is best i take them off the bike,i do have a bike jack and think i will buy a fsm for the job,having 2 books cant hurt.I have made a tool out of a syringe and 1/4 hose to service seems pretty simple,set it at 5.04 from top of tube (per clymer) and suck it out to get proper oil level.I appreciate the input i think i can tackle this and not have to pay outrageous amount of money at the dealer. Thanks again
To do the FXDX fork leg service properly you need a spring compressor. You have to remove the cartridge after you pull the spring, then pump out the last bit of fluid from the cartridge. Changing the oil an other way leaves oil in the cartridge.
If the FXDX forks are made by Showa be prepared for the most disgusting smelling oil. Don't know what Showa uses but I remember as a kid we'd call the engine oil they put in new Japanese bikes "fish oil." Used oil from Showa forks on my FXDL was worse. Spilled a few drops in garage and wife complained about the smell for days.
Buy this
http://www.traxxion.com/ForkServiceToolKit.aspx
and this, along with some Bel Ray fluid, new seals,fresh bushings and o rings.
http://www.jpcycles.com/product/607-...FY6Z4AodhS4AEA
