Dual Brembos
Dual Brembos
Just finished my Brembo upgrade. Used (slightly) OEM floating rotors and about 50% left on what I was told were aftermarket pads that came with the calipers.
I was so excited I got on the bike and proceeded to "test" the new set-up... Damn! They're good, REAL good! But, I didn't break 'em in properly and now there is a strong chatter in the front end on hard breaking. Also coming to a stop, it sorta surges, almost like the rotors are warped. Don't believe they are (two reasons; they look darn good, like new. And two, bought em from a forum member and I refuse to believe he would have sold me rotors he knew were warped).
Is there any hope that these will seat themselves accordingly? I hope I didn't permanently mess my rotors up... I think I just built up some "sticky" spots on the rotors that will eventually even themselves out...? haha. I hope so anyway!
Anyone have any encouraging words? or advice?
Thx.
Thx.
As to having to shim the calipers ( would be fairly rare as long as everything is factory. I assume the lowers you used are still stock ). Jack up the bike to get the front wheel off the ground and if it spins freely without drag your caliper position is probably ok. If it has resistance you may need to shim. Now you may hear the pads lightly hitting the rotors which is normal, but the wheel should spin free.
You do need to however look at changing to an 11/16ths bore master.
Don't feel it in the levers at all. Not more than anywhere else, anyway. It unsettles the whole chassis when under hard braking. It did seem to grow less and less as the short ten mile ride progressed...
As for shimming, was real smooth rolling. As smooth or smoother than stock. This was a bolt on affair for my DX (already had duals, AND the 11/16" bore MC). One must pick the correct rotors, however, as some require sinking the rotor bolt holes a bit so that the bolt heads do not make contact with fork sliders.
I'll nail it all with some cleaner as I did not do this before riding, only before mounting...
Thanks guys.
Thanks guys.
pads match calipers / discs
This is a 'just in case' ... were the pads still in the calipers and have you matched the calipers to the discs they were biting on? if they mixed up then it won't feel great, I'd be tempted if everything is lined up to replace pads and bed them in properly. Should be smooth with that set up... Longer shot I'd also check headstock bearings too if it's very twitchy.
