Thundermax Pigtail Harness USB Adapter
Hi guys,
Hoping someone on here can shed some light on this issue. I am working my stage 1 upgrade to my 2011 Street Bob. Screamin Eagle Round intake, and Short Shots. I was going to go with the PCV but after inspecting my bike I found out it had a Thundermax already installed.
So my issue now is updating the Thundermax map for my new combo. I have no way of knowing what was on the bike before. The dealer I bought it from told me it was completely stock as far as they knew.
Someone installed the "Pigtail" harness to the Thundermax for easy access for updating however I cannot find an adapter to USB anywhere with that type of plug? Below is a link to the Thundermax Tuner I have and a picture of the connect. Appreciate the help.
http://www.thunder-max.com/Products/...ms309-485.aspx
Thanks.
Thanks.
as far as I know the cable you need for that goes to the serial port so you'll probably want a serial-usb adapter also…
both available here:
http://www.zippersperformance.com/pr...mm-cables.html
Thanks for the quick reply. I don't have that serial port on my laptop. Might be able to use my buddies.
Do you know if I can use the micro usb to usb wire even if the pig tail harness was already installed? I know I have one of those lying around the house. I would have to order the other part.
Thanks.
Thanks.
The end you are holding plug into the Tmax, I have the serial-usb cable if you want, pm me ok. I have sold mine last year and got PV. email livetoridevan at hotmail dot com
I will sell it cheap!
Hi guys,
Hoping someone on here can shed some light on this issue. I am working my stage 1 upgrade to my 2011 Street Bob. Screamin Eagle Round intake, and Short Shots. I was going to go with the PCV but after inspecting my bike I found out it had a Thundermax already installed. I will sell it cheap! email: livetoridevan at hotmail dot com
Thanks.
Thanks.
