running on one cylinder!!!
so i went for a ride yesterday and got about an hr away from my house, i tried to turn into a parking lot to grab a bite and the bike sounded like a semi with a ENGINE BRAKE on. so i barley made it into the parking lot and found out she was running on one cylinder. this is what I've tested....
i have a power commander 3 with o2 eliminators.
i tried to disconnect the pc3 and replug the factory ECM and it wouldn't start i think due to the fact i still have the o2 elms still on but i can't find my factory ones..
i also tried my brothers coil on my bike still did the same thing.
i checked the crank position sensor and its good.
i check all my plugs and all seems good there also.
i don't have any trouble codes on the bike either.
i tried to check the injectors but the ohms on them are 0 on both
but i did find something just now..... i check my spark to the front head and it has none. the rear has spark. but i replaced mu coil with my brothers working coil and it still ran on the rear cylinder
i also cleaned up all the contacts on the PC3 and threw a lil die electric grease on them for good measure.. i haven't added anything to the bike in about a year and have never had a problem with it until now..
My 07 EGU goes in Wednesday for the exact same thing. I was 85 miles from home so turned around and ran that whole thing back in second and third gear wide open. Semi's were passing me on hills I was so slow!!!!! Checked the codes and it indicates a O2 or fuel injection circuit failure. Shop thinks a short.
