Lowrider owners! - Brake pad/lever question
A question on my lowrider (2008)...
I see all sorts of add-on brake pads, but none seem to fit a Lowrider... it apperas that the brake lever is an "all in one" unit... is that right? Have any of you upgraded your pedal to get rid of the boring rubber and add some chrome? What did you use?
I see all sorts of add-on brake pads, but none seem to fit a Lowrider... it apperas that the brake level is an "all in one" unit... is that right? Have any of you upgraded your pedal to get rid of the boring rubber and add some chrome? What did you use?
That may be because the low rider spec'd with mid controls. Since you have the forwards it becomes a search and try effort. I use all kinds of parts off of other models so that is what I usually do. Maybe search another Dyna that used the same type of controls you have.
