maury j Dyna Wide Glide issue
I have a 2000 FXDWG. Last week I rode over a rough cattle guard and the bike shut off completely. I coasted to a stop and had to wait several minutes before the bike would start again. The engine light stayed on and the bike will not stay running. Someone mentioned to me a shut down switch that may have been triggered and needs to be reset. Any ideas. Desperate in Burnet.
Received 4,309 Likes
Thanks for the quick reply. Let me retype the sequence I tried to make sure it is correct. With the ignition off, and the run/stop switch on run I turn on the ignition and cycle to stop then back to run. Then I cut the ignition off and repeated the sequence two more times. If this is correct the bike started but the engine light came on, then off so I'm assuming everything was not reset properly. Thanks again sir.
